2000 Saturn SL2 P0411 Air Injection
SATURN
ILUVMUD
I have a code P0411 Secondary Air Injection Malfunction on my 2000 Saturn SL2 . I replaced the EGR and it went away for a couple of days, but it's back. Any thots on fixing it for good?
Mar 22, 2006 at 12:02 PM
PEPPERMRJ
  • 1,158 POSTS
The code relates to the air pump itself that is located on the passenger front of the engine. It is a round black thing that has vacuum lines and electrical lines coming off of it. It also has a small diameter metal tube running from it to the center of the exhaust manifold.
I would start by tracing the vacuum lines and the electrical lines. Make sure all are intact and connected properly. I'm thinking you have a loose vacuum line.
Good hunting and let us know what you find. :)
Mar 23, 2006 at 1:20 AM
Suggested Repair
Inspect the secondary air injection pump on the passenger front of the engine. Trace the vacuum lines and electrical connections and confirm they are intact and properly connected. A loose vacuum line is the suspected cause. Also check the small metal tube from the pump to the exhaust manifold.
Conversation Summary
The owner of a 2000 Saturn SL2 reports a P0411 secondary air injection malfunction that returned a few days after the EGR valve was replaced. The expert says the code relates to the air pump on the passenger front of the engine and recommends tracing the vacuum and electrical lines, suspecting a loose vacuum line.
