noise while braking as well as pulsing pedal 2001 L300
2001 SATURN
SURFDUB
Hello I have a 2001 saturn L300 with 178,000 km on it. It had weak braking power and a rhythmic grinding noise but no pedal pulse. It wasn't that bad but I replaced the front rotors and pads. and almost right after the rhythmic noise reappeared but much worse and the pedal pulsates upon braking. the steering wheel doesn't move though...so I couldn't say warped rotors...and the noise is only under normal braking so I ruled out wheel bearings.
any suggestions??
Apr 18, 2006 at 9:38 AM
PEPPERMRJ
  • 1,158 POSTS
Did you replace only the front brakes? What about the rears?
Apr 18, 2006 at 3:55 PM
SURFDUB
no But how can you warp solid rotors?? I am not abusive rico sauve smooth....plus there seems to be a loss of braking power and the passenger front squeeks a bit. But could it be the rear?? please help me I don't want to get screwed over by saturn mechanics
Apr 19, 2006 at 12:34 PM
