My fuel gauge in my 1992 SL1 wont work.
1992 SATURN
MR_KALOHE
I changed the fuel tank and fuel injector and still my fuel gauge wont work. What could be the problem?
Apr 14, 2007 at 11:45 AM
PEPPERMRJ
  • 1,158 POSTS
Hey Mr K,
Did the gauge work before you changed the fuel tank? Was the old fuel pump reused or was it a salvage tank and pump?
It could be the sending unit, wires, or the gauge itself.
There is a three wire connector located under the carpet over the drivers rear wheel well. There are purple, grey, and black with a white stripe wires. Check that the connection is clean and tight. Also with the car running one wire should have 12 volts. Do not probe for more than a few seconds as you can ruin the gauge.
Good luck and let us know. :)
peppermrj
Apr 15, 2007 at 2:34 AM
PEPPERMRJ
  • 1,158 POSTS
Did you check all fuses?
Apr 15, 2007 at 2:35 AM
