How much toque for bolts that go from head to engine
SATURN
PMEDINA02
97 sl sohc 4 cyl I am putting a new cylender head but i don't know how much torque to on the bolts that go from the head to the engine, some one told me that if they had to quess it would be 50 lbs but i should really get this right so if anyone can help me out it would make my day.
May 30, 2006 at 6:53 AM
PEPPERMRJ
  • 1,158 POSTS
You tighten the bolts in sequence first to 22 ft-lbs then again in sequence to 33 ft-lbs. Lastly using a torgue angle gauge you tighten an additional 90 degrees in sequence.
Good luck and let us know. :)
May 30, 2006 at 10:30 AM
PEPPERMRJ
  • 1,158 POSTS
You are using new head bolts? They stretch to obtain proper torque.
May 30, 2006 at 10:35 AM
