waht is the quad driver and how do i repair it plase help because there is a fault
Apr 29, 2006 at 2:48 PM
JUANCBX3
MEMBER
where is it located and could it be turning off my car when i go foward because on reverse it runs fine but when i let the clutch go gently it runs but if i put it 1/4 throttle open it shuts of
Apr 30, 2006 at 11:23 AM
PEPPERMRJ
✓Experienced Mechanic
Make sure the EGR valve is not stuck open.
Apr 30, 2006 at 12:44 PM
JUANCBX3
MEMBER
i changed the egr valve once but it was used so do i replace it but the car makes like a poping bnag noice could it be it ill try it to see what happens thankx for the tip
Apr 30, 2006 at 3:59 PM
JUANCBX3
MEMBER
now i got a new code it's 42 bypass circut open or shorted from ignition mudule to PCM how can i scan it
