2001 Saturn No Start After Out of Gas
SATURN
DCHANCE4
If you run out of gas in your 2001 Saturn and it's fuel injection, when i put gas in it and it doesn't start, do i need to bleed the gas line or what do i need to do?
Dec 8, 2006 at 8:23 AM
BACKYARDMECHANIC
  • 337 POSTS
You may have damaged your fuel pump by running out of gas. If you have a fuel pressure testor check this out. If you don't, try and listen to see if you can hear the fuel pump work. Hope this helps. Good Luck :)
Dec 8, 2006 at 8:41 AM
Suggested Repair
Check fuel pressure with a tester, or listen to confirm the fuel pump runs. Running the tank dry may have damaged the pump; bleeding the line was not recommended.
Conversation Summary
The owner of a 2001 Saturn ran out of gas, and after refueling the fuel-injected engine would not start. They asked whether the fuel line needed to be bled. The expert said the fuel pump may have been damaged and advised a fuel-pressure test or listening for the pump to run.
