fuel in engine oil Saturn sc1
SATURN
LIGHTHOUSES
Why would there be fuel in the engine oil. and what would be the repair 4 it.
Jan 12, 2006 at 10:45 AM
GREASEMUNKE
  • 35 POSTS
Your valve seals could be letting fuel past into vavle train which would run into your oil.Also could possibly be your piston rings are letting fuel past into the crankcase.Check the cylinders with a compression tester or a leak tester.If you hear air towards the top of the engine that would be your intake valve leaking.If you hear noise coming from the exhaust then that would be your exhaust valve leaking.
Jan 29, 2006 at 5:54 PM
