i have a 1997 saturn sl2 dohc. it has 189,000 miles. i started having problems with it about 3 weeks ago. the temp gauge started to fluxuate between cold and the 1/4 mark and my SES light came on. it usually happened while at a dead stop. i took it to a local auto zone to plug in a diagnostic machine to it. it said that it was a problem with the transmission fluid temp sensor. i replaced both that and the engine coolant sensor, just in case. it did ok for a while, but then it started again. when the gauge goes towards "c" the engine will rev higher, and when warmer, it'll idle back to normal. So i replaced the thermostat thinking that would end it. as of tonight (4/13) the gauge went up to the mid-mark then back to cold while i was driving and my SES light came on again! Ugh! im just about out of options. HELP!! thanks.
Apr 13, 2007 at 3:32 PM
