Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Other
Engine Cooling
Coolant Temperature Sensor
COOLANT SENSOR
SATURN
COUNTS AUTO
MEMBER
WHERE DOES THE COOLANT SENSOR PLUG IN ON A 2000 SL2 W/V6
Oct 26, 2007 at 1:00 AM
SERVICE WRITER
Experienced Mechanic
Is that a trick question? The SL series never had a 6 cylinder, only 1.9 - 4 cyl.
Oct 26, 2007 at 1:08 AM
COUNTS AUTO
MEMBER
[quote:9966d8c445="Service Writer"]Is that a trick question? The SL series never had a 6 cylinder, only 1.9 - 4 cyl.[/quote:9966d8c445]MY BAD LS2
Oct 26, 2007 at 1:11 AM
SERVICE WRITER
Look below the rubber air snorkel connector on the left side front over the crank pulley. It goes in on an angle.
Oct 26, 2007 at 1:19 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
