Code P0102
SATURN
EJ1096
  • 5 POSTS
I have a 2002 saturn lw300, with 90,000. I got the code p0102 mass air flow low input circut. I cleaned the sensor, checked for clogs in the intake system, and reset the code. Code still came on. I replaced the MAF sensor. Code still came on. The car seems to run fine. it might have a little less response to the throttle than it used to, but I know thats because of what ever is making the SES light come on.
So any ideas, the MAF sensor has been replaced. This is driving me crazy.
Thanks for the help.
Jul 21, 2007 at 7:25 PM
CHEVY22
  • 1,375 POSTS
WAS THE PCM RESET AFTER THE REPLACEMENT , ALSO CHECK BATTERY VOLATGE RUNNING AND OFF
Jul 22, 2007 at 12:33 AM
EJ1096
  • 5 POSTS
[quote:daadff394c="CHEVYII"]WAS THE PCM RESET AFTER THE REPLACEMENT , ALSO CHECK BATTERY VOLATGE RUNNING AND OFF[/quote:daadff394c]
Ya after replacement the codes where cleared. When the code gets cleared it stays clear untill the car gets turned off. so I clear the code. drive the car. get to where I need to go. When i turn the car back on ses light and code return.
So the Batt. might do that to the MAF sensor?
Jul 22, 2007 at 7:29 AM
CHEVY22
  • 1,375 POSTS
VERY POSSIBLE . LOW VOLTAGE WILL CAUSE PROBLEMS IN MANY ELECTRONICS IN VEHICLES , AND DO A WIGGLE TEST AT THE MAF CONNECTOR TO SEE IF OT RUNS DIFFERENT
Jul 22, 2007 at 1:52 PM
EJ1096
  • 5 POSTS
[quote:89d90b1876="CHEVYII"]VERY POSSIBLE . LOW VOLTAGE WILL CAUSE PROBLEMS IN MANY ELECTRONICS IN VEHICLES , AND DO A WIGGLE TEST AT THE MAF CONNECTOR TO SEE IF OT RUNS DIFFERENT[/quote:89d90b1876]
i'll check the batt. and do the wiggle test. thanks for the ideas. I'll post when i do thoes and let ya know
Jul 22, 2007 at 7:18 PM
EJ1096
  • 5 POSTS
OK, I checked the Batt voltage. batt is good. Wiggled wires and no change in operation. The old maf sensor when I lightly tapped on it, the car would start to run rough then die. the replaced one I can lightly tap on it and there is no change in operation.
I have cleared the code with a code reader. It goes out till the next time I start the car after being driven. I have disconnected the batt. the code again stays out till the car is restarted after the inital drive
I got a chiltons book for it but that dosent tell ya squat. I was looking for a wireing diagarm and something that says what wires go where and what they should be reading when I put an oham meter on it.
I'm totaly out of ideas.
Jul 27, 2007 at 6:48 PM
EJ1096
  • 5 POSTS
I might just have to break down and take it in. Any body got any more Ideas? I really dont have the money for that.
Jul 29, 2007 at 8:07 PM
FMTHEFIXER
  • 11 POSTS
Check for a vacuumn leak
Jul 30, 2007 at 11:48 AM
CHEVY22
  • 1,375 POSTS
the diag sheet is way too long to run down , but if you go onto ondemand.com and check out diy you can purchase what you need for your can very cheapl and its good for one year and this is the whole car not just the maf circuit
Jul 30, 2007 at 11:31 PM
