Thanks,
2002 Saturn S-Series Won't Start
Thanks,
jim
Suggested Repair
Clean and inspect the main battery cables, grounds, and starter B+ connection for corrosion. Check for a parasitic drain from aftermarket electronics, the power outlet, or lights left on, using a voltmeter and pulling fuses and relays one at a time if needed. The key-jiggle start may point to a faulty ignition switch, so test before replacing parts.
Conversation Summary
A 2002 Saturn S-Series with 82,000 miles will not start without a jump, and the problem has worsened over five months despite a new battery and alternator. Charging the battery allows a few starts, and jiggling the key started it once. The expert recommends cleaning corroded cables and grounds, checking the starter B+ wire, looking for a parasitic drain, and testing the ignition switch before replacing more parts.
