BCM after repair issue
SATURN
SQUINTYT4E
Saturn SL2 2001 75k - front end accident, 2 days later remote key fob worked fine. 3 weeks later the day repairs were done - key fob doesn't work, rear defrost light won't go off, no alarm when door open with key in ignition or when lights left on, and when you press unlock inside the driver's side door stays locked. Repair shop says bad BCM but that their repairs had nothing to do with it....can I trust that?
May 9, 2007 at 10:19 AM
WSCREATE
  • 59 POSTS
[quote:63f742f319="squintyt4e"]Saturn SL2 2001 75k - front end accident, 2 days later remote key fob worked fine. 3 weeks later the day repairs were done - key fob doesn't work, rear defrost light won't go off, no alarm when door open with key in ignition or when lights left on, and when you press unlock inside the driver's side door stays locked. Repair shop says bad BCM but that their repairs had nothing to do with it....can I trust that?[/quote:63f742f319]
Get a second opinion, based on the work that was done. Have someone else confirm or rule out that the process of the work they did could have caused the bcm to go bad or what have you.
From a position of knowledge, if affirmative, go back to repair shop and relate your knowledge to them and ask them to fix it.
May 10, 2007 at 5:43 AM
