1992 Saturn SL2 Loose Belt Tensioner Fix
SATURN
OSWALDO21
okay, so I just got back from college, and my brother tells me the serpentine belt on the 92 SL2 1.9 DOHC that I gave him is loose enough to be just taken off by hand. I realize this is bad, and try to look at the tensioner... I can wiggle it around, so obviously it is loose; it's definitely not providing any tension on the belt. Can this be fixed or must it just be swapped out, and with how much expense are we talking? thanks, guys.
-adam in NY
May 13, 2007 at 12:54 PM
SERVICE WRITER
  • 9,123 POSTS
It must be replaced.
May 13, 2007 at 3:00 PM
SLIPKNOT44144
Well my Tensioner on 1997 Saturn is dead. and how do you replace it? It is almost impossible to replace IT!!!
Aug 16, 2007 at 9:34 AM
SERVICE WRITER
  • 9,123 POSTS
What model and what is the 8th digit of the vin?
Aug 16, 2007 at 10:39 AM
Suggested Repair
Replace the serpentine belt tensioner. A tensioner that moves freely and does not hold the belt cannot be repaired or adjusted.
Conversation Summary
The owner of a 1992 Saturn SL2 reported that the serpentine belt was loose enough to remove by hand and that the tensioner could be wiggled and provided no tension. The expert said the tensioner must be replaced. A later comment about a 1997 Saturn tensioner asked how to replace it, and the expert requested the model and the eighth VIN digit before giving further guidance.
