AC Pressure Switch
SATURN
LUCKYBLUE04
  • 11 POSTS
What do I do when I jumper the AC pressure switch with a paper clip and the ac fuse blows?
May 18, 2006 at 1:27 AM
LOSONE
  • 1,616 POSTS
Don't do it again because you are ground the A/C circuit. Why do you want to jump the pressure sw, low on refrigerant??
May 18, 2006 at 10:40 AM
LUCKYBLUE04
  • 11 POSTS
No, I am filled up with refrigerant. My ac system is new. I just wanted to see if the electrical system is malfunctioning...I was told that if my fuse blows when I jumper the switch, then it means I have an electrical issue and that is the reason why my compressor wont come on. I put a jumper wire from the battery's + terminal to the electrical connector on the compressor and I heard the clunk sound from the compressor kicking on so I know that is good. It just won't come on, and I am not sure at this point why? I need an idea of what I need to look for next....
May 19, 2006 at 12:49 AM
LOSONE
  • 1,616 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
When you do this I can help with the problem
May 19, 2006 at 1:28 AM
LUCKYBLUE04
  • 11 POSTS
Sorry about that...It's a 1995 Saturn SC2, 177k miles.
May 19, 2006 at 6:39 AM
LOSONE
  • 1,616 POSTS
Your car has an HVAC module which is the control head in addition there is an air temperature. These signals go to the ECM which provide the signals for the compresor to come on.
I have troubleshooting charts if you need a copy let me know.
May 20, 2006 at 10:16 AM
LUCKYBLUE04
  • 11 POSTS
Mr. Parmeter,
Please, if you could give me a copy of those troubleshooting charts, I would be very appreciative...Thank you. Also, I pulled a code from my Saturn yesterday and it was a code 26, but the manual I have for my car doesn't have that code listed, it is a little upsetting. Would you happen to know what the code is? Once again thanks...Garrett D.
May 22, 2006 at 1:35 AM
LOSONE
  • 1,616 POSTS
Code 26 is a Simtec code that has to do with the vehicle speed sensor.Do you have a speedometer problem or a transmisson shifting problem??
How did you get the code? Counting flashes are not accurate.
I will copy the troubleshooting charts sometime today and send them via E mail.
May 22, 2006 at 4:39 AM
LUCKYBLUE04
  • 11 POSTS
I got it by counting flashes. I believe it has something to do with my AC not working, when I read the link for trouble shooting the DTC 26, the section that applies to my situation is that when I ground the ALDL A to B, coolant fan kicks on instantly. Then it tells me to remove the ALDL ground and turn on the car and run the AC. I know my AC doesn't run, my compressor doesn't kick on. Therefore, the trouble shooting guide says to check for grounds. I have a digital multi-meter, I wanted to know if there is a way to check the plug holes that my AC relay plugs into with the multimeter? Otherwise, how do you check a relay for resistance. What prongs do I test out of the 4? In addition, is it true that if I get to my PCM and try to take a look at the wiring and unplug the connectors will I have to go to the dealership and get it reprogrammed? I am a little hesitant about messing with the PCM if that is the case. How far in handling the PCM can I go without having to reprogram it?
May 22, 2006 at 6:02 AM
PEPPERMRJ
  • 1,158 POSTS
Before you get to involved have you tried replacing the AC relay with a known good one?
May 22, 2006 at 9:45 AM
LUCKYBLUE04
  • 11 POSTS
yes. And I know my clutch works because I have, put a direct line to it from the pos terminal and heard the clutch "klunk" in the compressor.
May 22, 2006 at 11:57 AM
LOSONE
  • 1,616 POSTS
Check your E mail I sent the troubleshooting flow charts.
May 23, 2006 at 1:20 AM
LUCKYBLUE04
  • 11 POSTS
Hello Mr. Parmeter,
I didn't get the charts attached with the email you sent...if you are able to, can you try to send them again for the 1995 Saturn SC2? Thank you, I appreciate it... Garrett D
May 23, 2006 at 1:48 AM
