Failure to Fix Air Conditioning
SATURN
HALSEYCOURT
I own a 2000 Saturn LS2. I have a good number of miles on it and don't expect to keep it for too many more years.
The air conditioning is not working. "Room temperature" air blows out when the a/c is on. I am reluctant to get it fixed.
However, my friend told me that there could be engine problems that result by failing to get the a/c fixed if the problem with the a/c implicates the compressor.
What is your advice? Thanks.
Aug 18, 2006 at 3:45 AM
DODGECALIBERSXT
it sounds like you just need to have the freon recharged, should cost somewheres around 100 dollars. As for taking a toll on the engine, it shouldnt break anything if the freon is out, as long as the a/c is off, the pulley just freewheels. If you dont want to fix the a/c i would suggest unplugging the connector that goes to the compressor so it cant turn on.
Aug 19, 2006 at 2:07 PM
