1999 Saturn SC1 High Idle After Driving
Should be around $20.00 for the updated brass tipped sensor (ECTS) from the dealer. Just about as easy to install as a spark plug.
https://www.2carpros.com/forum/saturn-sc-1-1995-vt4925.html
Good luck and let us know. :)
Good for you taking responsibility for keeping your car running right. Researching problems and seeing that something is done about them is a trait that will serve you well all youir life. Don't be afraid to get your hands dirty with dad. You will learn even more. Wish my dad was still here. God rest his soul.
Now that high idle issue. Did you disconnect the negative battery cable while replacing the ECTS. Computers will need to relearn with the new part. Also check with dad on the condition of the connection for the ECTS. When that plastic tip cracks it can leak very small amounts of coolant that can corrode the connection. Sometimes they can be cleaned and other times they must be replaced. Pricey little piece of plastic and wire tho. About $30..00 dealer only item.
You can save some money ordering online for dealer only saturn parts if you order several items together. If not the shipping and handing will eat you alive. www.saturnparts.net is one such online dealer. there are several others.
The other thing to consider for the high idle would be a gunked up throttle body and a dirty IAC (idle air control) valve and port. I would recommend cleaning both with carb cleaner and an old toothbrush. I like to remove the throttle body to clean it. It is easier in the long run and especially facillitates cleaning the IAC and it's port which is part of the throttle body. This is something that should be done as preventetive maintenence anyway. So I would do it one way or the other. The IAC can also fail but more often is just dirty. Don't loose the $11.00 dealer only o-ring that seals the IAC valve. Reuse it with a thin film of vaseline when it is reinstalled.
I would clean the EGR valve and it's port at the same time. Good PM also. Have a gasket for the throttle body and EGR valve on hand. You can reuse the old ones if they are in good shape but for the small cost why bother.
Suggested Repair
The ECTS was already replaced and did not fix the high idle. Disconnect the battery so the computer relearns, and inspect the ECTS connector for coolant corrosion. Clean the throttle body, IAC valve and port, and the EGR valve and port; reuse the IAC O-ring with a thin film of petroleum jelly and have throttle-body and EGR gaskets on hand.
Conversation Summary
A 1999 Saturn SC1 with 112k miles sometimes idles at 1500-3000 RPM after long trips when the clutch is pushed in, returning to normal only after a complete stop. An oxygen sensor replacement cleared the service engine light but not the idle issue. An expert recommended the updated brass-tipped coolant temperature sensor; the owner installed one and the problem continued. Further advice was to let the computer relearn, check the ECTS connector for corrosion, and clean the throttle body, IAC, and EGR as preventive maintenance.
