98 saturn - car stutters on acceleration
1998 SATURN
MACROSS
I have a 1998 Saturn SL 1 168,000 KM on her. She just started stuttering or being jumpy(almost like a misfire or a bogging down) when you accelerate. She is also very slow to accelerate in the higher gears (manual transmission). She is fine once you are up to speed. I have already cahged the air filter, any other ideas of what the problem might be?
Aug 9, 2006 at 7:04 AM
SYNCRAIT
  • 235 POSTS
i would also go ahead and change the fuel filter it may be backed up and not putting through as much fuel as need during heavy accelleration.....good luck lemme know :)
Aug 9, 2006 at 11:24 AM
MACROSS
I just finished changing the plugs (fouled up) and has taken care of the problem. I will also change the fuel filter as well just because it should probably be changed.
Aug 9, 2006 at 11:31 AM
