97 saturn engine light
1997 SATURN
KMIG
  • 11 POSTS
it is a 1997 saturn sl2 with a 1.9l engine .it has a po341 code . does the car have a camshaft position sensor because of the code thats what it says it it is thanks?
Sep 12, 2007 at 11:38 AM
SERVICE WRITER
  • 9,123 POSTS
It does not mean that is what is bad, it means there are incorrect cam pulse being received by the PCM.
This may be an intermittant problem.
You need to know if there is an engine mis-fire, if not
The PCm , the Ignition control module or there may be a short to ground or an open in a circuit.
Sep 12, 2007 at 11:59 AM
