1994 Saturn SL1 Won't Shift Running
1994 SATURN
NICOLE.CARPENTER
I have a 1994 SL1, manual transmission. I went out to start my car yesterday morning and it woudnt shift out of reverse. When the car is running, I cant shift in or out of any gear but when it's off it doesn't have a problem. Also, there doesn't seem to be any pressure in the clutch at all. The past week or so it has been slightly difficult to shift when we first started it but after it warmed up it shifted fine. The clutch fluid was a bit low however after filling it, the problem didn't go away.
May 4, 2007 at 10:27 AM
PEPPERMRJ
  • 1,158 POSTS
Hey Nicole,
Sounds as if your clutch hydraulics are bad. Could be just a leak or more. Have it tested and repaired or replaced as needed.
Good luck and let us know. :)
peppermrj
May 5, 2007 at 6:51 AM
Suggested Repair
Have the clutch hydraulic system tested and repair or replace any leaking or failed components as needed.
Conversation Summary
A 1994 Saturn SL1 with a manual transmission will not shift into or out of any gear while running, though it shifts normally with the engine off. Clutch pedal pressure is absent. Shifting had been slightly difficult when cold, then improved after warmup. Clutch fluid was low, but topping it off did not fix the problem. The expert said the clutch hydraulics are likely bad, possibly from a leak or another failure, and recommended testing and repairing or replacing them as needed.
