1994 Saturn SL Hard Shifting
1994 SATURN
FELIXDACAT
I'm having the same trouble as an earlier visitor where the gears are difficult to change when I depress the clutch. The must car be off in order for me to shift into reverse or first gear and then it moves slowly once I start the engine, inching along as if the clutch is semi-released. However, the problem diminishes considerably once I've driven the car for a half an hour or so. I've been using the RPM and tach to gauge shifts and starting from a dead stop in second. Any ideas what might be happening here? I haven't tried any repairs or taken it in for a diagnostic yet.
Apr 4, 2007 at 12:32 PM
PEPPERMRJ
  • 1,158 POSTS
Hey Felix,
Sounds as if you might be having some trouble with the clutch hydraulics.
1 Is the clutch mastercylinder fluid full?
2 Try pumping the clutch pedal several times? Does the shifting improve?
3 Where does the pedal engage the clutch? If low to the floor there is a 90%+ chance the hydraulics are bad.
Good luck and let us know. :)
peppermj
Apr 5, 2007 at 4:33 AM
Suggested Repair
Check the clutch hydraulic system: confirm the master cylinder fluid is full, pump the clutch pedal several times to see if shifting improves, and note where the pedal engages. If engagement is low to the floor, the clutch hydraulics are likely faulty.
Conversation Summary
The owner of a 1994 Saturn SL reports hard shifting into reverse and first unless the engine is off, then slow creeping as if the clutch is partly engaged. The problem eases after about half an hour of driving. The expert suspects clutch hydraulics and advises checking master cylinder fluid, pumping the pedal, and noting a low engagement point as a strong sign the hydraulics are bad.
