2004 Saturn TEMPURATE GOES UP AND DOWN
2004 SATURN
SUMEKO
Engine problem
2004 Saturn V6 Front Wheel Drive Automatic 109285 miles
I HAVE NOT HAD ANY PROBLEMS WITH MY SATURN, BUT FOR SOME REASON THE TEMPURATURE THERMOSTAT RAISES UP AND ALL OF A SUDDEN IF GOES BACK DOWN....IT HAVEN'T RAN HOT OR IS LEAKING ANY WATER OF ANTIFEEZE....ALSO THE AC STOPPED WORKING IT ONLY GETS COLD WHEN I AM DRIVING.....WILL YOU HELP ME FIGURE OUT WHAT IS WRONG WITH MY CAR...................
Dec 10, 2007 at 7:37 AM
JUSTIN FREED
  • 87 POSTS
I suspect you have two separate problems. Sounds like the A/C may just need a charge...
The other could be air trapped in the radiator or block and not letting the water circulate properly or you have a bad thermostat.
Dec 11, 2007 at 1:39 PM
