2004 Saturn Ion Surge and High Idle
2004 SATURN
BONDYJD
I have a 2004 Saturn Ion Level 2 with a 2.2L,33,000 miles, and an automatic transmission. My car surges into second gear almost every time, but no other gears, and only while up-shifting. It also idles abnormally high when shifting the vehicle back into park after driving. It normally is at around 700-800 RPMs, but now it's at around 1,500 RPMs. If I try to shift it back into drive while idling this high it slams into gear. Have any ideas, or places where i could at least start looking?
Apr 11, 2007 at 12:19 PM
PEPPERMRJ
  • 1,158 POSTS
Hey bond,
I do believe you have a program issue that can only be addressed by the dealer. There are a few
TSBs that mention the need to reprogram the ECM and or the TCM due to engine surges at different times.
Good luck and let us know. :)
peppermrj
Apr 11, 2007 at 1:23 PM
Suggested Repair
Have a dealer check for TSBs and reprogram the ECM and/or TCM, which are associated with engine surge issues.
Conversation Summary
A 2004 Saturn Ion with a 2.2L automatic surges into second gear during upshifts and idles around 1,500 RPM in park after driving instead of 700-800 RPM, then slams into gear if shifted back to drive. The expert attributes this to a programming issue that the dealer must address by reprogramming the ECM and/or TCM per applicable TSBs.
