2002 saturn sc1
2002 SATURN
STEBBINS1
have a 2002 saturn sc1 1.9 4 cyl. 5 speed single overhead valve.
bought it new has 112,000 miles.
ck eng light came on high idle. vacuum leak number 1 cyc
pulled off entake manafold, replaced intake gasket, number 1 injector,
started up all ran fine for about 2 weeks
chk eng. light came on . bought a code reader \
got po 172 eng. rich bank 1
changed oxgen sensor, at front of eng.
code came back on po172 eng rich bank 1
changed three more sensors. still came on . took to shop checked cat. said was ok
took to another shop , kc martin, lynnwood wa.
said they could find nothing wrong, might need computer flashed, took to dealer, flashed computer, still comes on p0172 eng. rich bnk 1
I cant figure what to do next.
I put out the ck eng, lgt. and it stays off for about 1 to 14 days, comes on and goes off while driving.
any suggestions.
thank you
Ron
Nov 28, 2007 at 4:14 AM
EDI3000
  • 34 POSTS
Well try changing the fuel filter (which on this car is also the fuel pressure regulator) it could be sticking causing too much fuel pressure periodically.
Nov 28, 2007 at 10:52 AM
