2002 Saturn and good battery will not hold charge
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the battery load-tested, cable connections inspected and charging output checked. If those checks pass, have the vehicle tested for an electrical draw while parked.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Discussion summary
A 2002 Saturn SL2 reportedly restarted after a jump but would not crank after sitting for hours. The owner had been told that the battery and alternator were good, without providing test results.
Reported outcome: No follow-up test results or completed repair were reported.
The reply recommended verifying the battery and charging-system condition rather than accepting unreported checks. No failed battery, alternator, cable or source of drain was confirmed.
