2002 Other Saturn Models INTAKE MANIFOLD
2002 SATURN
82,000 MILES • 4 CYL • FWD • MANUAL
DUTCHMAN1
It sounds like I have a vacuum leak,I can hear something thats like a sucking sound around #1 intake runner on the intake manifold I can spray carberator cleaner around it the rpm's go up.I have already replaced the iac and tps sensors,but at the map sensor I am reading under 5 volts on one electric connection and on the other one ,nothing,and It should be reading the same.I was wondering if it could be another sensor and if I have to remove the intake manifold how hard it would be. THANK YOU
Apr 30, 2008 at 9:08 PM
LEGITIMATE007
  • 5,121 POSTS
the intake manifold is a sinch, make sure you check all vacuum hoses though , they can be deceiving. you could have more than one leak, is your engine light on?
May 18, 2008 at 10:44 PM
