After opening and cleaning my throttle body along with my EGR Valve my car continues to idle at right about 2000 rpm. No vacuum leaks detected.
Jan 6, 2008 at 7:55 AM
BLACKOP555
✓Experienced Mechanic
Check your IAC module, it may be causing it to idle high. is it a steady high idle or is it varing in idle? did you try to turn down the idle manually?
