2001 Saturn Engine Revs
2001 SATURN
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIMBOT
When the car is in drive but at a stop the RPM's rev extremely high. It does while it's in park as well but less frequently. I turn off the A/C and it still does it. This first happened about 3 months ago and then it stopped after a couple of days. Now it does it every time its driven. What could this be? Thanks
Dec 4, 2007 at 2:45 AM
SERVICE WRITER
  • 9,123 POSTS
Couple thoughts. a vacuum leak that is allowing unmetered air into the system.
I have seen a TON of coolant temp sensor that are bad on these. It sends the wrong signal that richens the mix up.
Dec 6, 2007 at 11:40 AM
