2001 Saturn car won't crank
2001 SATURN
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
EP2453
i replaced my battery a week ago. For a few days the car started no problem. I hit a bump going into a parking lot, parked the car, got back in and the car would not start. When I turn the key, everything lights up , i hear some sound from behind me (the fuel pump?) and the radio works, but when I turn to crank the engine, I get nothing, no sounds or anything. I can get it to crank every now and then, but not consistent enough to drive around town. I have people telling me that everything from the ignition switch, alternator, and starter need replacing. any ideas? i did check the fuses and they looked fine.
Dec 3, 2007 at 6:13 AM
When you turn the key On, do you see the lights that normally comes On-if not start by checking the battery and connections make sure its clean and tight.
If the lights are On-have helper hold key to start postion and bang on the starter-if the starter engages the engine you have a bad starter-if not backtrack starter circuit to the ignition switch start from the starter relay, transmission inhibitor switch/NSS,.
Dec 3, 2007 at 6:37 AM
EP2453
it is definitely a bad starter. any tips for getting that top bolt off? grrrrr....it's bad when the Haynes manual tells you that it is going to be "extremely difficult" to remove.
Dec 8, 2007 at 10:18 AM
