SMELL GAS MAYBE TIMING DO NOT HAVE TIMING LIGHT HOW ELSE TO CHECK.
Monday, March 3rd, 2008 AT 7:38 PM
SERVICE WRITER
MECHANIC
Will not turn over-no crank?
OR turns over-does crank, doesn't start?
SPONSORED LINKS
Monday, March 3rd, 2008 AT 7:50 PM
PIPPY
MEMBER
TURN OVER SOUNDS LIKE NO GAS GOES NA NA NA BUPE BUPE, NA NA NA BUPE, ETC.
Monday, March 3rd, 2008 AT 7:54 PM
SERVICE WRITER
MECHANIC
Gotcha.
IF there is strong fuel, Then I would first check for spark loss. Also pull a plug. If they are wet, they won't fire. May need to dry and clean, or replace.
Monday, March 3rd, 2008 AT 8:33 PM
PIPPY
MEMBER
MAYBE DRY OVER NIGHT THEN TRY AGAIN. FLOODED.
Monday, March 3rd, 2008 AT 8:50 PM
SERVICE WRITER
MECHANIC
IT might.I think it's more wishful thinking though. Pull them out and look at them, check for spark.
SPONSORED LINKS
Monday, March 3rd, 2008 AT 8:57 PM
PIPPY
MEMBER
HOW TO CHECK FOR SPARK.
Monday, March 3rd, 2008 AT 9:00 PM
SERVICE WRITER
MECHANIC
The best way is wth a spark checker.
Less safe is to pull the plug and keep the wire connected. Hold it to the block to ground it and crank the engine and watch in the gap area. This can cause secondary ignition problems however by doing this.
