2001 Other Saturn Models not passing ny state inspection
2001 SATURN
BOWIE36
Computer problem
2001 Other Saturn Models Automatic 112000 miles
the diocnostic hand computer is not showing any codes but when he pushes the button again four thing are not clearing catylisc converter,ooyxgen sensor and two other sensores, I had two oyxgen sensors replaced and it was reset and i was told to drive it to reset them but it has not worked i have driven in all different mphs and it is still not reseting what else can i do. or ask my machenic to check i have been to two different places for this.
Aug 28, 2008 at 12:41 AM
SERVICE WRITER
  • 9,123 POSTS
IF you have the 1.9 engine, remove and check your coolant temp sensor. IF it is a ceramic one replace it. I have had issues with monitors not running because of the criteria wasn't being met due to the sensor giving the wrong coolant temp reading.
Aug 28, 2008 at 1:14 AM
