2001 Other Saturn Models Engine problem escalated to its fin
2001 SATURN
297,000 MILES • 4 CYL • FWD • AUTOMATIC
MASTERS142
Two weeks ago my Saturn SL2 began developing a knocking in the engine when the car warms up. Mechanic I brought it to suggested Lucas oil treatment for 500 miles to see if the honey thick medicine would decrease the problem. I changed the oil and filter religously every 3000 miles since I bought it new in 2001. Anyway, the knocking, valve tap would disappear and reappear at will during my drive to and from work, sometimes during acceleration other times upon letting up on the accelerator. Then last Friday I drove a little longer, abot two hours and the noise got louder and louder. Got home chaneged oil and filter, pulled a plug out and the bottom was dripping with oil. Blown Cam?
Due to age? Options? Suggestions? Thanks in advance.
Mar 25, 2008 at 9:06 PM
2CARPRO JACK
  • 11,533 POSTS
Depends on if it is a fast light tap or a deep loud knock. The latter is a bottom end issue (crank/rods) the fast tap would be valvetrain and far less expensive to fix.
Mar 26, 2008 at 1:00 AM
