2001 Other Saturn Models
2001 SATURN
170,000 MILES • 4 CYL • FWD • MANUAL
BULLDOG76
MY CAR SEEMS TO RUN HOT WHEN I'M SITTING STILL VERY LONG AND I NOTICE THE FAN ISN'T COMING ON ANY MORE. DO I HAVE A FUSE TO CHECK OR WHAT DO I NEED TO DO THE I CAN'T RUN MY AIR EITHER CAUSE IT MAKES THE CAR RUN HOT. PLEASE HELP ??
Aug 20, 2010 at 9:44 AM
SATURNTECH9
  • 30,869 POSTS
So when you turn your air on does the a/c compressor come on?If it does does the radiator fan come on with it?Also do you have a multimeter or a test light?
Aug 20, 2010 at 9:53 AM
BULLDOG76
ITS NOT THE A/C ITS THE FAN THAT KEEPS THE MOTOR FROM GETTING TO HOT .
Aug 20, 2010 at 11:10 AM
SATURNTECH9
  • 30,869 POSTS
I know that when you turn the a/c on if it works then your radiator fan will come on and stay on.That's why I Asked you if the a/c works.If it works then does the radiator fan come on with it?Also do you have a multimeter or test light? so we can figure this out.
Aug 20, 2010 at 11:28 AM
BULLDOG76
NO I'M FEMALE AND I DON'T HAVE THESE THINGS THE A/C COMES ON BUT IT NEVER GETS COLD
Aug 20, 2010 at 12:16 PM
BULLDOG76
NO A FAN DON'T COME ON
Aug 20, 2010 at 12:24 PM
SATURNTECH9
  • 30,869 POSTS
Well if the a/c clutch kick's on and the radiator fan doesn't come on then someone need's to check and make sure the fan motor is getting both a power and a ground if it is then you need a new fan motor.
Aug 20, 2010 at 4:13 PM
