2000 Saturn SL2 Rough Idle Misfire
2000 SATURN
KMANMCDOULD
I have a 2000 SL2 with and automatic tranny and 106k miles on it. I know the timing belt needs to be replaced soon as the dealer had no record of it being done but i don't think thats related to my issue. On my way home tonight, keep in mind i drove it off the lot yesterday, the engine sounded rough. It was running with a stutter and every few seconds the tach would drop by 500rmp and shoot back up to where it was. When I got on the highway the tach shot up to 6000rmp before shifting. The Check Engine light was flashing when the engine stuttered but stayed solid on the highway. I've read that a lot of Saturn's from 98-2002 experience cylinder misfires. Any ideas what it could be?
Jan 11, 2007 at 2:40 PM
SERVICE WRITER
  • 9,123 POSTS
Need to know what codes are in the computer to halp narrow down possiblities. These are common for egr valve problems and more common for coolant temperature sensors. How old are the plugs and wires?
Jan 11, 2007 at 7:40 PM
Suggested Repair
Retrieve the stored trouble codes first. On these Saturns, check the EGR valve and, more commonly, the coolant temperature sensor, and inspect the age and condition of the spark plugs and wires.
Conversation Summary
The owner of a 2000 Saturn SL2 with an automatic transmission and 106,000 miles reports rough running, stuttering, tach drops of about 500 rpm, a tach spike to 6000 rpm before shifting, and a check engine light that flashed then stayed on. The timing belt is overdue but may be unrelated. The expert says codes are needed to narrow the cause and notes common EGR valve and coolant temperature sensor problems, while also asking about the plugs and wires.
