2000 Saturn LS2 Shuts Off at Red Lights
2000 SATURN
TERRACH145
I have a 2000 Saturn LS2 with about 60,000 miles on it. This car runs great but when you stop at a light for the engine just shuts off (not everytime). It usually starts right up after, but sometimes it takes a little while. When the engine shuts off it does not shutter or give you any indication that it is about to do so. The car was brought in for this problem and we had a variety of things done to it for maitance at that time but the Air Mass Flow filter (i think is what it is called) was what was replaced for this problem. The very next day the problem came back. We brought it back to the garage. But we were told after they had the car for a day that there was nothing wrong. Again the following day it happened again. Now the mechanic has had our vechile for 3 full working days. But they said they are cannot find anything wrong. We really need to be able to get this vechile back on the road. Can anyone help???
Feb 19, 2006 at 4:17 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. Electrical problems are a PITA. Two things come to mind, a failing crankshaft position sensor or the main underhood relay. There was a TSB out on the latter. If I find it I'll post it.
Good luck :) and let us know what happens.
Feb 19, 2006 at 11:29 AM
PEPPERMRJ
  • 1,158 POSTS
2000 Saturn LS2 V6-3.0L VIN R
Top - Vehicle
Technical Service Bulletins
. All Technical Service Bulletins
. . Engine - Intermittent Crank No Start/Multiple DTC's
Notes
BULLETIN NO: 00-T-28
ISSUE DATE: May, 2000
CATEGORY TYPE: Engine-10
CATEGORY: Starting/Charging
CORPORATION NO: 00-06-03-002
SUBJECT:
Intermittent Crank No Start with DTC P1780 Set in ECM History and/or U2105
Set in TCM or BCM History (Replace Main V6 Relay in Underhood Fuse Block [UHFB])
MODELS AFFECTED:
All 2000 L-Series Sedans and Wagons built before VIN YY630765 equipped with V6 (RPO L81) engines
CONDITION:
Some customers may comment the engine intermittently cranks but will not start and Service Engine Soon telltale is illuminated.
CAUSE:
The Main V6 Relay in the underhood fuse block (UHFB) intermittently may not function as designed.
CORRECTION:
Replace the Main V6 Relay using the following procedure.
PROCEDURE:
1. Disconnect negative battery cable.
2. Remove underhood fuse block (UHFB) cover.
3. Remove Main V6 Relay.
4. Install Main V6 Relay (P/N 12135170)
5. Install UHFB cover.
6. Connect negative battery cable.
Torque:
Battery Terminal Bolt: 17 N.m (13 ft-lbs)
PARTS REQUIREMENTS:
12135170 - Relay Asm-Acsry
Hope this helps.
Feb 19, 2006 at 11:41 AM
TERRACH145
I appreciate your insight. I'll let you know what happens. Hopefully it will be soon!!
Feb 20, 2006 at 6:24 AM
TERRACH145
I appreciate your help so much!! It [b]was[/b] the crank shaft position sensor. Our mechanic checked our car out for 5 days and could not figure it out. But thankfully do to your insight we are on the road again. I guess we should probably find a new mechanic:)
Thanks Again
Feb 22, 2006 at 5:32 AM
Suggested Repair
Replace the crankshaft position sensor, which the owner confirmed stopped the stalling. If needed, also replace the main V6 relay in the underhood fuse block (part 12135170), covered by a TSB for intermittent crank/no-start on early 2000 L-Series V6 models.
Conversation Summary
A 2000 Saturn LS2 with about 60,000 miles intermittently shut off at red lights with no warning and usually restarted. A mass airflow filter replacement did not help, and a shop could not find a fault. An expert suggested a failing crankshaft position sensor or the main underhood V6 relay. The owner later confirmed the crankshaft position sensor was the cause and the car was back on the road.
