2000 Other Saturn Models water pump
2000 SATURN
GOLF81
Engine Cooling problem
2000 Other Saturn Models Two Wheel Drive Automatic 94000 miles
I was wondering what the difficulty level is of replacing my water pump. I have been given approximately three different directions on how to do this.
Aug 20, 2008 at 10:03 AM
JARVIS HOLLOWAY
it's not too hard i removed the air compressor from the bracket (do not remove lines) and set it to the side you also have to remove the water pump pulley and you should see the pump has 6 bolts that holds it in place and you have to take off the right front wheel and splash shield
Sep 13, 2008 at 10:42 AM
