2000 Other Saturn Models Sent this as a PM to merlin, just p
2000 SATURN
90,100 MILES • 4 CYL • FWD • MANUAL
JBURR84302
The codes that I'm getting are:
P0304, P0300, and P0341
The Make/Model/Engine size are:
Saturn/SL/1.9L
In case you're unable to find my last post this is what it said:
My 2000 Saturn SL is getting a cylinder 4 misfire code and what is happening with the car is that the idle when it is stopped bounces and almost dies, and also when I drive it when I am trying to keep it at a constant speed with the gas pedal only about 1/2"-1" down the car bounces alot as if it was struggling for gas. I have ran 3 tanks of fuel injector cleaner in it and replaced the spark plugs, I'm quite the novice mechanic so do you have any other ideas?
Thanks for your help,
Jason
Jan 17, 2008 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
So the code is P0304? Engine size..?
Check the coil for cyl 4, and the connection to the
EI module most are near the radiator...
This answers your PM
Jan 17, 2008 at 7:19 AM
MERLIN2021
  • 17,250 POSTS
That 341 tells me you most likley need a new EI mod and coil...
Jan 17, 2008 at 7:22 AM
MASTERTECHTIM
  • 4,750 POSTS
indeed merlin. we just had one of these a couple of days ago and the guy went round and round. the fix was replacing the ignition module and coil.
Jan 17, 2008 at 7:27 AM
