With key in run postion and engine off, press the oil reset button and hold for 5 seconds. (Button is in the fuse box under hood on left side engine compartment) If the Change oil soon light is flashing, then the system is reset. The light will flash for 30 seconds or until ignition is turned off. If the light comes on for 30 seconds at next ignition cylcle, the system did not reset and need to be done again.
Sep 23, 2009 at 9:29 AM
