2000 Other Saturn Models High Beams Turning On
2000 SATURN
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
OZAMORA
Hello, I recently purchased a Saturn LS2. Everything works great except for the headlights. When I use the turn signals, the high beams come on. This also happen occasionally when I am driving, the high beams come on randomly. What could the issue be??
Jun 4, 2010 at 5:30 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like you need a new head light switch very common for those car to do that when the switch goes bad.If you have any more question's let me know.
Jun 5, 2010 at 10:33 AM
OZAMORA
Is it an easy and cheap fix? Like is it something I can do myself if I get the switch myself?
Jun 10, 2010 at 4:21 PM
SATURNTECH9
  • 30,869 POSTS
It's really easy to change I think the switch is like 40-50.If you don't change it i have seen them smoke and turn the head light's on by themselves and kill the battery.All you have to do is pop the cover off unplug the switch sqeeze the two tab's pull the old switch out put the new one in.Let me know if you have anymore question's.
Jun 10, 2010 at 4:37 PM
