2000 Other Saturn Models Could this possibly be something ot
2000 SATURN
GERETTE64
Transmission problem
2000 Other Saturn Models 4 cyl Automatic 80000 miles
My son has a Saturn (I'm not sure of model or wheel drive type). Two days ago, it started hesitated when he went from 25 to 30 mph. Yesterday, however, it started making a clunking sound when it shifts into a different gear, or he puts it into reverse.
I called our local mechanic and he told me my son is looking at about $2,500 if they need to replace the tranny. He said though, that we should bring it in to be sure it is the transmission, as it could be something else.
Any ideas what else it could be with these symptoms?
Feb 23, 2010 at 1:04 AM
GERETTE64
Never mind. It was his transmission.
Feb 25, 2010 at 3:15 AM
SATURNTECH9
  • 30,869 POSTS
was it the whole transmission because the input shaft nut loosens up on those and causes reverse problems it will even get so bad u will loose reverse and the pressure regulator in the transmission goes out and causes reverse and s****** problems.it not always a transmission replacement fix most of the time they can be fixed without taking the transmission out even.let me know what u find.
Feb 25, 2010 at 3:58 AM
