2000 Other Saturn Models brakes
2000 SATURN
VICKI POSTON
Brakes problem
2000 Other Saturn Models 6 cyl Front Wheel Drive Automatic
have replaced brake pads; master brake cylinder; and bled brakes multiple times; but pedal goes to floor when depressed on first attempt; will pump up after 1st depression; stumped please help
Jul 1, 2010 at 12:58 AM
AUTOZONEBRAKESEXPERT
  • 47 POSTS
Hi Vicki, I'm Randy. I reviewed your question, and wanted to provide information that might help.
If it still seems to take a long time to stop the car when applying the brakes, where you have to push the pedal down hard to come to a complete stop:
* This condition is often due to ‘brake fade,’ which occurs when the linings become too hot. It may be caused by linings that are too thin or brakes that are overworked.
* This condition may also be caused by air in the hydraulic system, a fluid leak in master cylinder, a hose or line leak in system, and/or if the brakes misadjusted.
* This may also be an indication that the rear (or front) brakes that are not operating as designed. This requires the front brakes to work harder resulting in overheating and longer stopping distances.
Thank you for the opportunity to discuss your question. Please let me know if you have any further questions.
Apr 24, 2011 at 12:02 PM
