2000 Other Saturn Models blower motor fan
2000 SATURN
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
NCROGER
My heater/hvac blower motor will not run. I have replaced the relay, fuse is good, replaced the resistor, still motor will not run. tested motor directly to battery and it runs. I get 12 volt at the blower motor connection but when I plug the motor in and turn on there is no voltage. I created a second ground but the same results. I tested the voltage at the motor connection, with the fan switch off there is no voltage, in all of the speed positions I get the same 12 volt readings. I am stumped?
Jun 14, 2008 at 6:25 AM
MERLIN2021
  • 17,250 POSTS
Check switch continuity.
low= D&B
Med-Low= D&C
Med-High= D&E
High= D&F
I will post the colors, computer problem right now!
Jun 14, 2008 at 6:47 AM
MERLIN2021
  • 17,250 POSTS
https://images.2carpros.com/forum/automotive_pictures/62217_AC_Switch_1.jpg
Jun 14, 2008 at 7:14 AM
NCROGER
[quote:823e533a01="ncroger"]Electrical problem
2000 Saturn SL2 Models 4 cyl Two Wheel Drive Automatic 130000 miles
My heater/hvac blower motor will not run. I have replaced the relay, fuse is good, replaced the resistor, still motor will not run. tested motor directly to battery and it runs. I get 12 volt at the blower motor connection but when I plug the motor in and turn on there is no voltage. I created a second ground but the same results. I tested the voltage at the motor connection, with the fan switch off there is no voltage, in all of the speed positions I get the same 12 volt readings. I am stumped?[/quote:823e533a01]
I left the ingnition off, disconneted the blower resistor and performed the continuity test to the resistor plug connection for each bank of wires. I did this for all of the switch settings and all came back with an open circuit except when switch was in the first on position then I got a closed circuit on the brown to yellow connection but the blower motor will not run at this`setting. What is next
Jun 14, 2008 at 9:21 AM
NCROGER
Jun 14, 2008 at 9:22 AM
MERLIN2021
  • 17,250 POSTS
This test was for the fan speed switch....What is the continuity there?
Jun 14, 2008 at 10:47 PM
NCROGER
I tried to pull the switch module out but I could not get it far enough out of the dash to test. Guess I will have to take it to the dealer.
Thanks for all your help
Jun 15, 2008 at 4:31 AM
