1999 Saturn SL Car dies upon starting
1999 SATURN
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALUCARD23
Replaced fuel filter, spark plugs, air filter, and regular oil changes. When I start the car it will rev high than die within a second unless I give it gas for about 2-5 seconds. Once this initial startup is done the car idles and runs fine usually. Sometimes after giving it gas from being stopped at a stop light it will stall briefly, <1 second. If I let the car die upon startup the only way to start it again is to hold the gas pedal all the way down while turning the car over. Any help/suggestions will be greatly appreciated.
Mar 15, 2008 at 6:41 PM
  • 75,988 POSTS
Inspect and test the idle air control valve and throttle position sensor-
Mar 15, 2008 at 7:08 PM
