1999 Other Saturn Models Surging engine, etc.
1999 SATURN
62,000 MILES • 4 CYL • 2WD • AUTOMATIC
NEPLEY23
My 1999 Saturn SW2 is having a issues involving the engine and related parts! A couple months ago the coolant temperature light started flashing and I was told by the dealership that I needed to replace the Engine Coolant Temp Sensor. I did this. A couple weeks later the coolant light started flashing again with the service engine light came on as well. Soon after, the engine started to surge. About two days later, I filled the tank with gas and the car would barely start with the engine surging to 2500-3000 RPMs. A few miles down the road the radiator burst. The following has been performed on the car: New radiator, new ECT, new spark plugs, air filter change, coolant flush, transmission flush, and water pump replaced. The car generally seems to run fine for three-five day intervals, then the check engine light will come on, the engine will surge drammatically, and once the car is turned off it will not restart without a "jump". Now it just sounds awful and not really available to drive. Usually, it appears anyway, that the car starts acting up soon after I get gas--this could be my imagination. Help!!! I love my car, but I don't know what to do!!! Thanks!
Jul 22, 2008 at 10:17 AM
99SW HATER
the temp sensor not only controls the fan when your motor gets hot it also talks 2 the computer & controls fuel & eminshions..buy the lifetime replacement sensor ($10 @orioles) because they go out frequently & i have bought bad sensors i had one that worked 4 a week & went bad i replaced it & it lasted for about a year
Nov 11, 2009 at 7:43 AM
