1999 Other Saturn Models Oil Mixed with coolant
1999 SATURN
13,200 MILES • 4 CYL • 2WD • AUTOMATIC
SHAUNABAY
  • 8 POSTS
Car over heated, replaced the thermostat first, then the water pump started leaking, replaced that. Then after that the coolant started getting milky, like it was mixed with oil, flushed it out. Now, the reservoir is full of oil, and it boils over, but the oil dipstick is fine, there is nothing mikly on the dipstick.
I thought it was a cracked head, but there is nothing on the dipstick, so......help me out.
May 15, 2008 at 5:35 AM
MERLIN2021
  • 17,250 POSTS
Have a look at the tranny cooler lines, if they screw into the radiator, it could be thre oil tank in the radiator cracked. Check the tranny dipstick also.
May 15, 2008 at 5:52 AM
