1999 Other Saturn Models Oil in the cooling system
1999 SATURN
KE5LIQ
Other Category problem
1999 Other Saturn Models 4 cyl Front Wheel Drive Manual 138K miles
I am losing the motor oil to the cooling system, what is the cause? How much might it cost to repair?
Feb 6, 2008 at 2:05 AM
MERLIN2021
  • 17,250 POSTS
Could be anything from an internal crack in the block, to a head gasket, although most head gasket problems don't put oil into the radiator, the coolant burns in the cylinder and goes out the tailpipe...either way it will be expensive...A used engine could be the option...
Feb 6, 2008 at 2:10 AM
