1999 Other Saturn Models high idle
1999 SATURN
128,000 MILES • 4 CYL • FWD • AUTOMATIC
TFAMILY05
I'm working on a 1999 sc-1 , 1.9 single cam I've checked the vacum hoses and found no leak the same with the gasgets I've replaced the idle control valve and the egr valve with no change The car idles down when cold but increases as it warms up (1800-2000 rpm) I've ran the engine and plugged the vacum lines and even the throttle body and still it continues to run at 2000 rpm's . What am I missing ?
Jul 13, 2008 at 10:31 PM
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
Jul 13, 2008 at 10:57 PM
