I CANT FIND THE FUSE FOR THE DOME LIGHT IN MY CAR. I CHEKED BOTH FUSE BOXS AND NOTHING IS MARKED AS DOME LIGHT. CAN YOU HELP?
Jan 23, 2010 at 12:44 PM
SATURNTECH9
✓Experienced Mechanic
the fuse for that is ur body fuse its in ur inside fuse box under ur passenger side foward kick panel just in front of ur center console.make sure the fuse is good and has power but if that fuse is blown other things would be inop.for that yr and model the most common reason form the dome light to be inop is a loose blub or bad blub make sure u have power and ground to it.the orange wire is power.let me know what u find.
