1998 Saturn SC2 major engine issues
1998 SATURN
DGOULD
1998 ( 07-97) Saturn Sc2 1.9l DOHC
105K Manual transmission
I acquired this car in a trade. It had an bad engine. After investigation the engine had blown up and broke the block on the back side near the #1 rod. This engine was a replacement from a wrecking yard. So I bought another used engine and it had a rod knock from the front half of the engine. The yard exchanged it for me. Well after 41.2 miles of driving this engine blew up. Guess what? It threw the #1 rod. Same as the engine I took out the first time.
So my question is, Is this a common problem? I am willing to swap an engine one more time but that is it. Can I use a newer or older style engine that is a direct bolt in? So far I think that Saturns are junk. Thanks for the help, David
Oct 12, 2007 at 11:27 AM
SERVICE WRITER
  • 9,123 POSTS
All cars are junk. You just ran into bad luck, but buying used parts is like playing russian roulette. The saturn isn't a bad car all in all, but you may want ot consider a reman engine such as jasper. The junk yard can better advise what years fit which ones if you want to go through it all again, but beware of having to swap more parts in doing so. They had an oil consumption problem that can eventually lead to your failures you've had.
Oct 12, 2007 at 12:32 PM
TOM187
[quote:0bf225a376="Service Writer"]All cars are junk. You just ran into bad luck, but buying used parts is like playing russian roulette. The saturn isn't a bad car all in all, but you may want ot consider a reman engine such as jasper. The junk yard can better advise what years fit which ones if you want to go through it all again, but beware of having to swap more parts in doing so. They had an oil consumption problem that can eventually lead to your failures you've had.[/quote:0bf225a376]
Oct 26, 2007 at 12:07 AM
SERVICE WRITER
  • 9,123 POSTS
I think I heard an echo :shock: :?
Oct 26, 2007 at 12:24 AM
TOM187
[quote:cd72842fc1="Service Writer"]I think I heard an echo :shock: :?[/quote:cd72842fc1] What I was trying to find out was,what is the oil consuption due too?? I have a 98 Saturn SCL2 with 118,000 twin cam and so far no oil consumption
Nov 6, 2007 at 10:21 AM
SERVICE WRITER
  • 9,123 POSTS
I guess I missed that part.
The Saturns needs frequent oil changes as the oil rings begin to become a problem. From talking around, I've heard a few things I'll pass along. We have never had to go into one, mostly becasue the customer did not want to.
If a ring job is done it is suggested the cylinder be checked for a taper, may need block work as it is soft, that can be done w/o pulling the engine. Some attempts to clean the top end of the engine may be helpful with a de-carbonization treatment such as seamfoam be used or GM top end cleaner. By adding the seam to each cylinder and letting it set overnight will help break down the carbon and free the rings. The motor must be turned over after an overnight soak with out any spark, and then some added to the oil for that oil change period. Using a high detergent oil for a couple thousand miles can help.
Nov 6, 2007 at 9:59 PM
