1998 Saturn 110000 miles
1998 SATURN
HLFRIESZ
resently changed the heater / radiator and there is two lines that connects to the transmission, one upper and a lower one on the radiator which I forgot which one goes in the right side or left side? The lines are the same size and the holes on the transmision is next to each other and yes they are the same size also, this is not dummy proof. Can any one tell me which line, top or bottom goes in the left or right connection on the transmission, and if it will harm anything if I connect them up backwards, Thanks.
Feb 20, 2007 at 9:26 PM
KIN CHAN
  • 453 POSTS
shouldn't make a difference ...but blow thru both inlet and chk if there air both both direction....safest way is stop by a local salvage yd and chk a few cars ..we got cross sometimes on transmission exchange machine but it never trip the machine saftely feature...so ur chance of crossing lines cause damage is very low...good luck man
Feb 20, 2007 at 10:13 PM
