1998 Other Saturn Models Speedomneter want work
1998 SATURN
137,566 MILES • 4 CYL • FWD • AUTOMATIC
SNATCHER
i had it put on a computer says speedometer sensor was not good replaced it ,speedometer or odemeter neither 1 will work its like its not communicating with computer alseo changed speedometer cluster still want work its a 98 saturn Sl 2 also i changed computer can you help me?
Sep 23, 2008 at 10:14 AM
MERLIN2021
  • 17,250 POSTS
Usually it turns out to be bad solder points on the board itself, check the solder on the pins at the speedo connector part of the circuit board.
https://images.2carpros.com/forum/automotive_pictures/62217_cluster_1.jpg
Sep 23, 2008 at 10:22 AM
